Sounds like your glow plugs aren't working. Kubota engines struggle to start without glow plugs. You just need to do some electrical checks. Connnect a test light to where the wire connects to the first glow plug. Turn on ignition and see if you have power on the wire. If not, start going back through system looking for what's causing power loss.
If power is present, you need to test your glow plugs. There is a resistance reading you can do with an ohm meter, don't remember what it is though, Bobcat dealer may be able to tell you. Otherwise, you could remove the jumpers going from #1 to #4 glow plugs. Connect a heavy jumper wire from battery connection at starter to each glow plug individualy, check current flow on jumper wire with amp probe. Look for glow plug or plugs not pulling amps, or pulling very low amps indicating failed glow plug.
