repairing final drive case
ditchdiggerjcf
arkansas
anybody out there had any luck repairing damaged teeth in the case of a final drive? I am reluctant to try it with a fewgrand tied up in new planetaries, bearings, etc.....
AmerIndependent
Site Sponsor
Riverside, CA
Caterpillar Powertrain Rebuild & Repair Specialist
What teeth are you talking about? The sprocket teeth or gear teeth? What model tractor are we talking about?
Hotwheels81
Up north, eh!
You mean fixing the teeth on the sun gear that the 3 planetairy gears turn? Perhaps due to one or all of the planitairy gears fail causeing broken teeth to the sun gear?
If thats the case i would buy a new sun gear because the cost would outweigh the savings if the welding lets go and takes the planetairy gears out.
QuickTrax
Houston
Depending on what machine you have. You can probably find a aftermarket or good used fairly cheap.
MANUEL NAUT
Dominican Republic
hydromechanic engineer
i am 100% agree with hotwheels81. you are going to rely on the uncertain quality of the repairment of the teeth. is this is an excavator you will have the complete final drive failure and probably the hydraulic motor as well. if new parts are expensive, try the used parts market, which feeds from dismantled machines.
ditchdiggerjcf
arkansas
been looking for salvage pats for months. apparently there are none to be had. The case on a final drive has teeth machined into it. When the bearing let go it damaged the case. the case is no longer available.
stock
Eire
We have moved on and now were lost....
What breed ,make and model are you looking at?
jrtraderny
New York
Be nice to know what machine, one of us on here might have one or know of one.
jr
jrtraderny
New York
How about a picture of the damage?
Real hard to say it can be fixed or not looking at a blank post........................
jr
