drrick
I have a '98 ford f800 dump truck, w/air brakes, 33k gvw, 8.3 cummins and 6 speed allison. need to pull a trailer with electric brakes. I am trying to find a line or switch that can act as the feed to the prodigy controller. so far all of the feeds I have found that give 12 volts when the brake peddle is pressed , also give an intermittant feed when the turn signals are actuated. Does anyone know if there is a brake light switch that I can use or do I have to install another air actuated switch in order to install the controller. I only use these units on the ranch and sparingly, so I won't be buying the more usefull air brake type trailer. The belshe triple axle tag is paid for and plenty strong.
thank you in advance.
rick roberts
rick roberts
