Hi,
I am new to this forum and thought I might start out by providing some repair information that I hope others might be able to use. Later when I am able to post my own questions, you guy's will probably wonder if I even know how to start my 1845C.
Anyways, my real full time job is being a maintenance tech for a very large distribution center, and my side job is welding and fabrication. One of my customers operates a construction business, and I have repaired 2 of his Bobcats with the same problem as in the above post and photos. On each side of the cylinder bushing I welded in some 2 piece reinforcement brackets. The reason they were made in 2 pieces was because I could not get a sharp enough radius on the bend when I first attempted it. It has been a while, but if I remember correctly the brackets were made from 3/8" cold rolled steel plate. Knowing that bushing replacement may be needed down the road, I removed the existing bushings, and had a machine shop make I guess you would call them over length bushings. I then welded the bushings and reinforcement brackets on with 3/32" Excelloy 61S rods. The reason I chose this particular rod was because I was not sure of the alloy properties of the parent metal. The 61S rod is a high tensile strength (up to 128,000 psi) and high yield strength (up to 90,000 psi). It also has up to 30 percent elongation which is good when dealing with unknown or dissimilar alloys. It also has a work hardness of up to 198,000 psi. This rod is actually designated as a stud pull rod used for removing broken studs, bolts, taps, and the notorious for snapping off easy outs. I have even removed 3/8" bolts that were broken off 2 inches below the surface. Anyways, I feel that this rod is perfect for this type of repair because the reason for failure is mostly due from metal fatigue. A welding alloy with a high elongation spec usually works fairly well in areas that are prone to flexing and fatigue. Although, I would think that Bobcat would be more concerned about areas that should not really be flexing at all. Sorry about rambling on about the rod and alloy info. I do have some photos and drawings of the reinforcement brackets if I can find them, and will post them when I am allowed to do so......in 2 more replies I think.
I think this is a very organized site, with many very knowledgeable people, and look forward to tapping into some of this experience if the need arises for my 1992 Case 1845C with 1827 original hours on it.
