littleplows
- Joined
- Sep 20, 2007
- Messages
- 22
- Location
- Erie, PA
- Occupation
- Business Owner - Recycling Natural Waste, Snowplow
I have a couple of questions for you guys that are smarter than I with these things.
I am looking for a cold start injection system for a diesel engine does anyone know where I can find one used.
Is there a propane injection cold start aid or is it just starting fluid/ether.
I would like to use propane instead of starting fluid because of starting fluid taking away all the lube in the cyls and poss contact with the injectors. I already have a block heater installed and it works ok but when it gets to freezing temps around here it doesn't seem to be enough. What I have been using is some fluid film injected after the filter and it works great to start the machine but the cans of fluid film don't like to work when its that cold either.
You guys who haven't tried it would be amazed on how easy a hard starting diesel starts when you use Fluid Film instead or of or in combination with starting fluid.
