Richard
Hi Guys,
I'm hoping with the vast amount of experience here in the forums, maybe you can give some tips on solving my problem cause I'm stumped.
I have a JLG 45ic manlift. I went to use it the other day and it would not move. Everything else works perfectly but when I move the joystick to drive, nothing happens. The engine does not load up at all....just does nothing. Well, after a bunch of testing and studying my service manual, I found the test readings on the HorsePower control card were not correct. Included in the control box is a bypass connector to bypass the HP control card. So I unplugged the HP control card and plugged in the bypass connector and it worked! I thought.....plug in the HP card and it won't move, bypass the HP card and it moves....this has GOT to be the culprit! So I remove the card and sent it to Hindley Electronics for repair. After about a week, they send it back saying it only needed some minor adjustments but checked out fine. GREAT! I re-install the card back in my machine and it's no different than when I sent it in. Still won't move.....voltage readings on the card at idle and high speed are still the same as before. I unplug the card, connect the bypass, and it will move again.
I'm stumped. I don't know what to check next. Any suggestions?
Thanks,
Richard
Thanks,
Richard
