You should find a plug with the wiring as follows;
509 White. Speaker left common.
508 Purple. Speaker left.
512 Green. Speaker right common.
511 Brown. Speaker right.
200 Black. Ground.
122 Red. 12v +ve unswitched.
It gets a little weird now on the schematic I'm looking at. Your one remaining wire is, according to the schematic, a 191 White, but 191 White should be for the air seat suspension. I'm thinking it's a misprint on the schematic. What you should actually have is a 129 Blue. This will be your 12v +ve switched feed.
Check out the wiring to the plug and if you have a 129 Blue then all is good with the world and the sun will rise again tomorrow.
If you have a 191 White then Cat have made a mistake somewhere
and you'll have to probe it with a meter to see if and when it becomes live.
Brabe. Your machine isn't pre-wired for a radio. You'll have to pick up a switched and unswitched feed from maybe the ignition switch. Don't forget to fit fuses.
