AtlasRob
Hi I know its not really the the right thread to post it but it seemed the closest. We have just brought a CAT TH62 (2001) but after driving it along the road when I got back to the yard and turned it off the hour clock, oil pressure light and load monitor stay on even after the ignition switch has been turned off. Soon as its started the oil light goes out and it runs like a dream.
I thought it was the igniton switch as it was a bit battered and after spraying a bit of WD40 it stopped doing it once so I have changed that but it still does it. I have also looked for loose wires but can seem to find any. The only thing I can think of is if it could be a relay and if not where the loose wire could be.
I was just wondering if anyone had any experience of it and what could be causing it. Also if anyone knew where I could get a operators manual for it as I have tried ebay and finnings but they'll take 5 to 6 weeks.
Thanks
Welcome aboard Cathandler.
Sorry cant help you. Make another couple of posts to give you 3 then start a new thread with the title being the problem and you should get some replys.
