I have an overhaul manual for 53 Series, injector height is determined by type of piston and type of injector along with gear train timing. Do you have trunk type pistons, crosshead pistons, turbo charged or non-turbo'd. Some use N45 or N 50 injectors .
Some use a whole bunch of different injectors for turbocharged trunk type piston versus crosshead pistons.
I do not have the parts book so determine by piston type and design of engine.
Better post more information, and if you have never set the governor linkage including the idle and buffer screw, be aware that in 3 seconds the motor will be grenading if not 100 % and injectors stay full fuel.
Good idea to find an old guy who did lots of them, and if the peerson does not know what the vise grip pliers are for just run and don't look back. Any seasoned 53 mechanic knows what they are for. But each to their own.
Simon C
