Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
This is the rear steer ram cylinder where it connects to the spindle. It actually should connect at the rear of the spidle arm behind the center bearing with the messed up circlip.
Did 3 of those last year. What happens is the tapered pin gets loose in the spindle and starts to rock. Then it shears off the threaded part on top and when the cylinder gets loose it breaks off the top of the pin that slides thru the cylinder bearing. One I worked on sheared off the bracket that holds the hyd lines to the drive motor. Wiped out a couple lines. Had to replace two of the spindles due to excessive wear in the taper. Wouldnt hold the pin correctly. Not a fun job!
I've been driving these for over 6 years and have only seen this happen once. I have seen the the center bearing weld break away from the axle on top also.
