stinky64
- Joined
- Feb 25, 2017
- Messages
- 911
- Location
- java center ny
- Occupation
- big truck wrench/fixer of things
That is one of the best DIY procedures I have seen. Awesome job, I'm going to buy a triple nickel just to rebuild it.
One side of mine was leaking bad. I thought it was due to the bushing being worn so I bought the bushing o rings and seals. Once I got it apart, I couldn't find any failures of the parts. Turns out the vent was plugged forcing the oil out when it warmed up and pressurized. Cleaned vent. Problem solved. It was a straight forward job and I don't recall any hardship in doing it. Now, I always check vents first.Anyone ever change a hub seal on a 555e? Both of mine seem to be in bad shape as they leak oil down the backside of the front tire. It’s not terribly bad, but enough that I need to fix it soon.
I’ve looked over the manual and it seems to be straight forward, but wondered if anyone had any tips?
I also just realized the hubs take hydraulic oil for some reason. I’ve been putting gear oil in there. Whoops.
My vent of the front axle was bad as well and I had oil coming out of both sides. I fixed that a while ago and there isn’t oil on the driver side anymore. However when I went to check the oil last week I noticed the passenger side was almost dry. Well now I know what the real cause was.One side of mine was leaking bad. I thought it was due to the bushing being worn so I bought the bushing o rings and seals. Once I got it apart, I couldn't find any failures of the parts. Turns out the vent was plugged forcing the oil out when it warmed up and pressurized. Cleaned vent. Problem solved. It was a straight forward job and I don't recall any hardship in doing it. Now, I always check vents first.
I can’t get these bolts out to save my life. Lucky guy.After you take your lug nuts off, there are two 5mm Allen head bolts that hold the planetary cover on. This is what the cover looks like off the machine. There is an o ring seal.
Well now I feel better knowing yours wasn’t a cake walk hahaI had a lot of trouble with those as well. I used a quarter inch impact driver with a 5 mm hex socket along with heat cycles from a small map torch and WD-40 around the threads. I ended up buying new ones because of how chewed up they were from the impact. I also snapped the hex Allen type socket during this process. It was a pain.
1998, I very much appreciate you posting these. My huh rebuild was fairly simple minus a few issues but some of your pictures came in handy. Such as when I knocked my thrust rings off the bench and didn’t know the order.After you take your lug nuts off, there are two 5mm Allen head bolts that hold the planetary cover on. This is what the cover looks like off the machine. There is an o ring seal.
I have fixed several leaks by opening up stuck or clogged vents. Always the first thing I check too.One side of mine was leaking bad. I thought it was due to the bushing being worn so I bought the bushing o rings and seals. Once I got it apart, I couldn't find any failures of the parts. Turns out the vent was plugged forcing the oil out when it warmed up and pressurized. Cleaned vent. Problem solved. It was a straight forward job and I don't recall any hardship in doing it. Now, I always check vents first.
