Hi everyone
I recently purchased a Hitachi EX300LC-1 in reasonable condition for a small granite mining operation. The machine will be using an NPK hydraulic breaker for around 50-60% of its operating time. I am unsure about the viscosity of hydraulic oil which should be used in the excavator since the information I am receiving regarding this from different sources is conflicting. Any help or advice from esteemed members would be greatly appreciated (Apologies for the long post!)
Background
The previous owner had already filled up the tank with new ISO 68 oil before sale. Since he was a reseller, he was unsure what was being used in the machine before that. When I inquired about his choice of oil viscosity, he said thicker oil works better with the older machines and requires less frequent replacement. I have also asked two other local mechanics who regularly work with older EX models and both are adamant that ISO 68 is the correct choice. Infact they claimed they have never used anything less than an ISO 68 on the machines they have worked on in the past.
On the other hand, the local Hitachi dealer insists that ISO 46 is the correct choice and using a thicker oil will cause hydraulic pump cavitation and failure.
Doing some research online I found information regarding hydraulic oil ambient temperature ranges that was equally conflicting. Some sources said that ISO 46 ambient temperature range is -4°C to 21°C (+25° to +70°F) and ISO 68 ambient temperature range is +4°C to +32°C (+40° to +90°F). While other sources said ISO 46 is designed to work in ambient temperatures of -20°C to +35°C (-4° to +95°F).
Further information
a) The machine has twin axial piston pumps
b)The weather in winters (Nov-Feb) minimum is about -4°C (25°F) to a maximum of say 10°C (50°F)
c)The weather in the summers may be a minimum of 10°C (50°F) in the mornings with afternoons going up to 25°C (77°F) usually, but sometimes even up to 30°C (86°F)
d)The machine will be using a hydraulic breaker for around 50-60% of its total operating time
Query
1) Considering that summers are just around the corner, can I safely use the existing ISO 68 oil without any damage to the pumps and change it to an ISO 46 in about 6 - 7 months before winters?
2) Considering the conflicting temperature range information online would I then need to use a 68 in summers and a 46 in winters or can I then keep using the ISO 46 throughout the year.
3) Does the significant planned hydraulic breaker usage have any impact on the decision of oil viscosity being used? (possibly because it would further raise the operating temperature of the oil when being used)
Thank you!
Background
Further information
Query
Thank you!
