My recently purchased and well used D6B has a leak at the hydraulic pump that appears to have been leaking (a drip about every 10 min when running) for a very long time. It seems to originate from the connection of the discharge hose. Somewhere along the way the discharge hose was modified and made shorter. I got a new hose made for the discharge and also replaced the hose segments on the suction hose. Reassembled with new o-rings and after a short run found it still to be leaking, apparently where the discharge line bolts to the pump. Next I got a new set of the "blocks" that hold the hose end against the pump and a new o-ring, drained the tank, reinstalled the hose with new blocks, new bolts, and a second new o-ring. It still leaks. The seating surface on the pump looks good, btw. I don't know why it leaks.
I should also mention there is also a fairly loud "whine" noise when the engine is running that comes from the pump. It loud enough to be noticeable but I don't know if it's normal or not. There is also a vibration in the the discharge hose but perhaps this is normal for a gear pump?
I thought of a couple of possible explanations but they are only guesses:
1. There could be a crack in the pump case into one of the bolt holes? I didn't see that but it would cause a leak like I see. Such a crack or even porosity in the casting might provide a leak path that is not visible from the outside.
2. Is it possible the pump is overpressuring the line? I don't know if there is a regulator in the system, but I would suspect there is, maybe inside the hydraulic tank. Anyway, no other connection on the system has a problem and the hydraulics operate just fine.
I'm checking pricing for a new pump. Looks to be about $800-$1000 with shipping. Some of those advertised don't show the manufacturer and I see China listed as origin on most. I'm curious if anyone recommends a good aftermarket pump.
I am attaching a few pics, some before and some after I worked on it.
