skyhightree1
Hey what warming aid(s) do yall like best for your Diesel equipment ?
CD, basically you put two 'tees' in the heater hoses of the machine, and two in teh truck you drive. Of these 'tees' run hoses with quick connects on the ends. When you get to the site in the morning, plug them in, hop in your truck for a coffee, and after 10-20 minutes, the antifreeze in the machine should be getting warmed up fairly well.
Basically the same effect as a block heater, but doesn't need electricity to work. Some guys get fancy and put in shut offs and various setups, but that's it in a nutshell.
After zero just go home and forget about it. It's too damn cold for bears or men.
This sounds pretty ingenious, something I never thought of. While it may work in some cases, I can't see it working in others. Most newer pickups, for example, have aluminum blocks and require special anti freeze to protect the aluminum. Heavy equipment on the other hand requires special diesel anti freeze that one would not put in a pickup truck. Hooking the two systems together would mix the different antifreezes and could cause premature corrosion and gasket failure. Or am I missing something?
