BRL
Here's one I had to do a couple of weeks ago - 10 - 15" at places Me thinks we found where the concrete truck got to dump it's extras when they poured the foundation :laugh Spent a couple of hours with the Bosh electric hammer trying to make a cross in it so we could hopefully break it into 4 at least. I can't remember which number model machine the mini ex is, but it couldn't lift it at all to drop it a little. I wasn't there for the eventual solution to get pics My sub has a new truck with a 5 ton grapple. So he picked up the also way overpoured but thankfully just a step for the other single door back there, and dropped that a couple of times to break up the big slab.
I wouldn't rent a saw for these situations, but since I have one I do use it. In this case I saw cut the cross into the top, then when the hammer was going in, it was getting much deeper because it had a start already. Plus the cuts will add to the leverage forces when doing the lifting & dropping method or the lifting & setting a timber etc under them to drive on or hammer away method. Definitely helps get them broken quicker.
