camptramp
- Joined
- Aug 13, 2013
- Messages
- 6,302
- Location
- The warm land on Vancuver Island
- Occupation
- Retired Logger Retired Part time pebble hauler
That HDX Hayes looks a lot like the Wahkash #12 HDX Hayes in post # 3035 Hayes Trucks in the logging Industry .
The driver shared that photo & I believe you are correct in it being Wahkash's.That HDX Hayes looks a lot like the Wahkash #12 HDX Hayes in post # 3035 Hayes Trucks in the logging Industry .
I'm sure there is a story on how that happened . I hope the truck wasn't messed up to bad getting the logs off it and out of the ditch .
Bruce tells me the Log Loader was the first rubber tire machine to cross the bridge/culvert . A log that was used to build the "crossing" broke , causing the loader to end up where it did . There was a Grapple Yarder in the area and there was Grade Equipment building road in the area . The rescue of the machine took a little more than a day . Damage was minimal , after standing the loader up on its wheels , fluid levels were checked and topped up or changed . Engine was turned over by hand , then engine started up .How long did the recovery take ?
A very smart Logging Truck Driver . When things go wrong , they go wrong in a hurry . When they do , look for a soft spot and ditch it . The truck is not a write off , the driver is not off work injured and the 15-16 foot bunks and stakes took most of the abuse . Well done .Yes this is all correct, I know the driver. He started losing brakes and put er in the ditch at like 4mph. Suffered just a couple scrapes on the truck and some broken water tank bolts.
