jbender
I've put in a lot of work into this machine this summer, and gave it it's first real job today (trenching for water and electric to a chicken coop). I bought it recently after it sat for 10 years. It has run many times this summer without any hint of engine issues. Always started right up and ran smooth.
It ran for a couple hours without any issues. Got about 50' of trench dug out. There was some howling from the front - which sounded like belt noise (not saying it was, necessarily). Still ran strong engine wise (the hydraulics seemed to weaken as it warmed up but that is a different issue for a different day).
The engine started to sputter and the RPM's dropped. Usually I can grab the throttle and get a bit more out of it - and it springs back and goes a bit slower (normal for it - maybe others do that, too...). When it's having issues, I no longer get a bit more speed out of it by pulling on the throttle lever.
- Tried pulling the air filter - no change
- If you let it sit for a little while, it will start right up, run at full speed, but then start to drop in RPM
- It got progressively worse - it runs for only a very short time at full speed now.
- Lots of smoke when it does this. Runs rough.
- Took both fuel filters off and drained out what looked like a bit of crud. They otherwise look decent and are pretty much new.
- Plenty of fuel flow out of the secondary filter purge port (after I added some more diesel to get the level high enough to purge the air...)
- I added some Standyne lubricity formula fuel additive this morning for the first time (obviously wish I hadn't now to make the guesswork easier). Heard this was a good idea for old machines, but what do I know.
- Fuel pump is a Roosa Master Model #: DBGFCC 431-64AJ
Video link of it running. Kinda long but I wanted to show you how it slows down a bit at a time.
I'm guessing at least one of you know what kind of pain I'm in for! Thanks for your help!
-Jason
-Jason
