Do they sell these plugs on back of ignition sw , case 580se
Birdseye
Topeka Kansas
D6458264-E726-4035-87B2-F35852D1D315.jpeg BA2061ED-C4D5-4855-AA09-3B9AC746B7A8.jpeg Hi
does anyone know if these plastic plugs or wire holders that connect the wires to the back of the ignition switch on a case 580, are available anywhere ?
The length of the harness is so short it’s necessary to use the plug to get the correct wires hooked up. Mine is sort of melted and deformed.
If I can’t find a new plug, Ill remove the ignition switch from the console panel , hook up the wires to the switch then connect the ignition switch to the console. It’s just a little harder to do.
