Okay I’ll look into that. I believe there are two adjustments? One with the counter weights, and your suggestion through the front inspection hole correct?You probably need to tighten the pony clutch.
Sorry it didn't go well. Did you ever crack the engine drain plug to check for water sitting in the bottom? Of course makes sense. I been pretty occupied with all the other issues that I never really looked and put much thought into it. Then I looked in my service manual and I don’t believe I can find it anywhere that suggests doing it that way. Thank you!! Anyway all fluids look good. I have yet find water such as you did which is hard to believe. I feel before all went south for my late uncle who’s D4 this was it was in good shape 12 years back. The pony motor compression is excellent and no thrust movement at all in the crankshaft bearings. Maybe yours without a engine cover made this worse? As I stated before the top valve springs look great, and I removed the aft left side crankcase panel and all looks great in the bottom half. Problem lies in the top piston area I’m sure where moisture got in from someone removing the air cleaner other parts for their own purposes. While underneath removing the drain plug for the dry bay clutch there is a plug missing from the fwd flywheel bay? I’m assuming you have one there? I guess I will have to find one at some point if I get this running. Looks to be the same as the others.
The transmission fill is at the breather, you put a wrench around the square area and the whole plug backs out, it's like a 2" npt thread.
You might want to consider getting a bore scope for the next time you go. You can get one for around $40 that will sync with your phone and it will let you find out if it's a specific cylinder that's stuck or if it's something else completely (timing gears rusted, flywheel stuck, etc). Especially if you are driving two hours each way, it might be worth it to just keep you from potentially barking up the wrong tree as far as diagnosis goes.
I think that is a very good idea. I have had this week off so was planning a couple of trips, next one this Thursday possibly. I'm not sure I can get the right one before I go, but will definitely get one. It be perfect also for the pony pinion clutch I'm trying to figure out. I believe its currently engaged but if that is the case I don't believe I should be able to turn the crank pulley of the pony motor which I'm able to do since the main engine is locked up. I can put my hand around the pinion gear and feel it rotate don't understand why its not meshed with the flywheel which it should be. That scope could shed some light maybe.
The hole at the bottom of precombustion chamber is 0.2", not sure if the cheap ones have that small of a tip.
Well I have some good news, not the news on what I really want but I will settle for small victories! I did finally get the main clutch freed up. I was able to get access to the clamp bolt on the adjusting collar and loosen the bolt. It wasn't easy but finally broke it loose. Then I had to take a brass drift and hammer to loosen it up.So now it moves back and fourthOn the pinion clutch, the pinion is probably not snapped into engagement with the flywheel ring gear. This is done with the horizontal lever to the right of the clutch lever, pull up to engage. The clutch is forward to engage, rear to disengage.
