Volvo 160C screen problems
farmerlund
North Dakota
Farmer/ excavator
Working on 160c, Display stays gray and only says Volvo. It never changes. Auto decelerator works, Thumb works. The climate control and the radio are nonresponsive. Is probably the cab control computer? Is there anything I can try before I get the Volvo technician involved?17FEC765-5432-435F-A822-52C3293CA2E2.jpeg538C5E23-CDDC-4A8F-8A45-7A224D0C5C38.jpeg
uffex
Lincoln UK
Admin
Good day
Any history surrounding the failure? please check to see if the manual switch is fully selected.
Kind regards
Uffex
  • Like
Reactions: DB2
funwithfuel
Will county Illinois
Mechanic
The fuse box in the first compartment immediately behind the cab. Check all fuses and relays. Sometimes, you can lose a relay which powers up half the CAN. It sounds like you lost HMIM & HVAC ECUs I will check schematics when I get in to see if I can find a common denominator.
farmerlund
North Dakota
Farmer/ excavator
No history on failure. Guys I got it from says it was like that the entire time they owned it. Didn’t get used much.
We looked over fuses. Didn’t swap any relays around yet. Thanks
uffex
Lincoln UK
Admin
Good day
The Most probable cause is the display you could make sure you have a good ground to the unit and a good can bus connection.Often such failures are the result of careless welding or jump-starting.
Kind regards
Uffex
farmerlund
North Dakota
Farmer/ excavator
Tried swapping relays around, and checking fuses. No results yet. It also drains the battery bead if we leave the disconnect on. Takes a couple days.
uffex
Lincoln UK
Admin
Good day
That sounds as though you may have a short in the circuit or the battery is going bad.
Kind regards
Uffex
farmerlund
North Dakota
Farmer/ excavator
So we got the 160 screen fixed. it was the cab computer. had it replaced now everything works the way it should.
