Grizzly Trucks
Will_M
DeWinton, AB
Pictures don't do it justice but painting and reassembly has begun.
Top of the roof, sun visor and glove box door are done. Satin black on the inside of the firewall, steering column, shifter knobs is done, burgundy paint on the interior will hopefully be done today or tomorrow.
New chrome has started to arrive, things are moving quickly now!
Will_M
DeWinton, AB
Quite a bit of progress the past couple of weeks.
Roof and interior have been painted. Horns and cab lights installed. Electrical is basically done. Stacks, grab handles and mirrors have been mocked up. Air conditioning system has been replaced.
Is there a way lower the stacks some? Unless something really high is going behind the cab I think it would look more proportionate with the stacks about 6 to 8 inches above the cab. The truck will look great when it's all put back together.
There is a big Surerus yard in Gibbons I drive by when I go out to my property. They have a lot of equipment.
Are you putting the spare tire up on the headache rack too?
Will_M
DeWinton, AB
No, I think we're going to mount the spare vertically on the headache rack below the window.
Im not 100% certain about that yet.
diamondtguy
Mapleridge..BC
machine fitter/fabricator
Will...are you changing the wheels to something a little more truck like over that what was on it ???
Will_M
DeWinton, AB
20221003_105952.jpg 20221003_105857.jpg 20221003_105837.jpg 20221003_105822.jpg
Paint is done, reassembly has started.
It's s really starting to come together and it looks awesome!
Plan is to take it down the road to the engine shop hopefully early next week to get the engine, transmission and transfer case pulled out to address any leaks and repairs needed. They're going to detail and paint the components as well while they're out.
crane operator
sw missouri
Is the truck going to have a short jump seat against the back window, or are you just putting front seats in and leaving the back for storage?
Will_M
DeWinton, AB
It's going to have a back seat out of a Chev extended cab.
It's going to be mounted so the bottom will still fold up in case the space is needed.
Old Doug
Mo
[QUOTE="Will_M, post: 1076530, member: 77385"
Plan is to take it down the road to the engine shop hopefully early next week to get the engine, transmission and transfer case pulled out to address any leaks and repairs needed. They're going to detail and paint the components as well while they're out.[/QUOTE]
Very cool i have often thought about building something like a Grizzly or cutting down a cabover. You must know a very special shop to take on a job that is freshly painted or they need work bad.
