I guess it would work, assuming it's a straight road there
Here they can get 140,000lbs on 8 axles. Depending on weight of truck and wagon, you'll get over 100,000lbs of payload. Depending on the site, all they need is room to back the wagon close to 90 degrees which for a good driver isn't much and it'll be dumped in 2 minutes. If it's a really long haul like 2-3 hours roundtrip on a straight road I could see where that combo might make sense, but it would need a football field to turn around in, or you'd be replacing tires every week on it. Other setup you see here is a b-train end dump on the rear and a lead side dump, no unhooking or backing up that way can dump both in a straight line. Bit more limited in what they can haul though.
I mean if you're doing say 90 mins roundtrip, 5 trips a day, that setup will cost you 1 trip a day and that's without any screw ups, it would negate a bit extra hauled very quickly. I wonder how long the average truck goes before a driver forgets to undo a air line or electrical? Or forgets to hook up electrical? Doing it 5 times a day, it's only a matter of time.
I will say i'm glad we don't have those weird setups here. No tag axles, no truck lift axles none of that random axles hanging off every point of the truck. Just straight regular axles that make sense. When I look at those pictures it looks like photoshop, or someone on something who came up with the insane idea.
