Do you have access to Cat ET? If not, can you read the diagnostic codes off of the monitor? Prob going to need ET to see what the output of the HPCR pump is during cranking. Do you know what RPM the engine was turning when it “ran away”?
Not E459-2 by any chance was it.?As far as codes go, the only one it set was engine horsepower over specification
That's the one!Not E459-2 by any chance was it.?
Thank you!I’ll send you some information on a PM but it will be tomorrow before I can do it.
Those symptoms would appear to point to a major issue in the HP fuel system although it is strange there are no Codes generated.Ok so I found that it will start and run if I cap the fuel supply to cyl #1. Doesn't set any codes, but it won't throttle up. It will only run at about 700 rpms. Hooked #1 back up and plugged the remaining cylinders. It wouldn't start with cyl#4 capped. With cylinders 2 and 3 capped I got the same results. Started and ran, but no throttle response. It appears the pump is weak.
It doesn't add up, but I agree. How does the ECM control injection pump output? Id like to verify ECM has control before hanging a HP pump on it.Those symptoms would appear to point to a major issue in the HP fuel system although it is strange there are no Codes generated.
. I missed this bit, this is what I needed to know. I'll hook my scope onto the SCV and check duty cycle from ECM and amplitude of the SCVTry this for fuel system, first one was incomplete
What did you ever figure out with this machine? I have a 236d and pretty much having the same issue as you. But mine started shortly after I had the dpf filter cleared. I missed this bit, this is what I needed to know. I'll hook my scope onto the SCV and check duty cycle from ECM and amplitude of the SCV
