Tinkerer
There is more to a flush that purging the lines.
The cylinders ports have to be opened, and then the the rod needs to be extended and retracted to purge all the contaminated oil out of it.
If it isn't done properly you will not get all the crappy oil out of the system.
It takes a lot of new oil to do it. The last time I did it, it took 35 gallons of new oil.
A filter cart is a better way to do it if you have access to one.
