David Friedt
Hello, I have been fighting a problem with my JD 762 elevator chain that quits when put under a heavy load, it seems that the charge pump looses pressure and then the elevator chain stops, and the pumps howl at the same time, I took the charge pump apart and it looks like new inside, I also put a small shim in the pressure relief valve and the pressure increased on the gauge but still drops to zero under a load, I did pressure tests at the elevator motor test ports and I only get about 1500 lbs before it quits. I hate to buy a new hydrostatic pump and still have the same issue, I have replaced the inlet filter, and the oil level is full and I drained and replaced the oil with new JD hydraulic oil, My machine serial number is 002310T , and it has a sunstrand hydrostatic pump for the elevator system model 22-20 65H , I also shimmed the 2 pressure relief valves at the motor trying to find a solution? Can anyone please help?? Dave in Decatur
