Happy 2023 HEF - hard to believe we're about to roll into 2024!!
Also want to Thank all of you for putting up the various info/pics you have, I much rather read about these "issues" than the news! I know I've learned a ton...in fact- here is where my transmission distraction occurred...
So, you guys saw I pull the screen/magnets and didn't find fuzz or chunks; definitely a positive sign, but the "TO-2" oil I used just wasn't sitting well with me...so after searching the various names/suppliers listed above (for TO-4 30) I found Lucas TDTO-30 oil delivered for $89/5gal (and free shipping from Summit Racing)...I also got a new filter and o-ring...then the "lessons that others where going thru" kicked in- and yes, the oil/filters are still on bench waiting to go in!?!
Must have been late June/early July I kept reading guys having stalling issues/running funny complaints - most starting points were "have you looked in bottom of fuel tank"? AND "have you opened the low-point drain"...It occurred to me - I had done neither. Should add this was around the time I was refitting the rebuilt rams back on the machine (separate thread with its own side-projects) AND trying to dodge the rain drops all the while trying to make bales of hay (which we were 39% off production this year b/o bad weather, but good part it gave me time to figured out how to adjust/fix a square baler - what a REMARKABLE feat of engineering still in use today). but I digress...
Now I should add, I've been happy with how the machine runs, with the exception of how the machine first starts - just cranks too long (~30-40 seconds)...but going off the previous owners info "don't worry about fuel filters, I've been thru those"...being a "trust but verify" guy I thought I should look at the bottom of tank AND I should open the low point...certainly has to occur at some point.
SOOOOO...off comes the tank cap, remove the clip that holds screen (which I can't believe is still with the machine)...shine flash light (torch for you Aussies!) into bottom of tank - SHOCK - it's PERFECT!! No sign of any crap!! ...then I realize, great I'm gonna open that low-drain and that b*****d will never seal back up (realist not a pessimist! so I have 30 gallon drum ready)...crack the screw open...bit of a pause, then she drains great and surprisingly seals back up...a real 20-minute job!!
Then it hits me, I better check those fuel filters up front - that's when the $-hit hit the fan...the first stage screen was 2/3-3/4 FULL of rust/crap- absolutely sicking feeling...then pulled the plug for the secondary filter housing - WATER...DAMNIT(!) why did I not start with the filters a YEAR+ ago...then I removed the filter it was just CAKED with crap (I'm still pissed at myself- everyone knows (or should!) always start with the fuel filters)...anyway...
That then highlighted my fuel primer plunger was weak/junk and the old pressure gauge on the secondary housing was filled with condensation - after ordering/replacing those parts finally got her back to running state (still not perfect, thinking my transfer pump is likely weak??). Also took the time to remove the faded plastic cover from the hour meter and polished that, now the non-functioning hour meter is visible!?! May roll that rebuild into the transfer pump project (time will tell).
So I definitely feel like I took 3 steps forward and two back, but on the other hand I now KNOW I have a (remarkably) clean tank/drain along with reseting the filters so at least I can keep track as I go.
Just so thankful I got the rams off/resealed...they were making a ridiculous mess and needing constant oil added...as with all my the tasks on this dozer leads to many more - playing the game "while I'm here"!?! I will say - I am SOOOO impressed with Cat and my ability to get parts for this machine, I feel very fortunate...I'm sure the day will come I hit the Oh crap situation, but at this point so far so good.
I do wish my machine was indoors (for many reason) and that I was closer to the machine to keep chipping away at the repairs, but right now I'm getting prepared for undercarriage removal/rebuild and down the road, radiator removal/cleaning along with water pump check, belts/pulleys...but I need to prove a couple more things work before I go that deep, and with the way time is passing by me...it might be the next guys issues!!
Sorry to be long winded, but when I stop loving to hate my iPhone (or is it- I hate loving my iPhone!?!?) and can get on a laptop/keyboard, I can add pages vs sentences!!
Couple notes:
- Did change both air filters too - thinking the 1978 date "might" indicate they've been in use a while!
- Fuel primer ...the fine threads on the body of the plunger are NOT the same from the original to new...don't have real data, but if you look at pics, new one only has 2 set-nuts vs 3 on the old
- John Deere square bale pic is just for "show"
