cat 420f2 code help
Ros$
SE Oklahoma
have a 2018 420f2 with some issues. hear are the codes showing
BVAYXFjj71J6nbBYtXs32JEjMTiREdFglfR9Y8O4GhrGI-eXF2u8wRQj3EyVn9p51YNAEmXhuwOJAwb38S_og_kClCcepieYcnZAbTNE_iLTVvjygJSkpl2WhLX9fQK37tbcWhww42TIelDZ_U8U5rA7n8Lu71hZbvMAvHAbJhLxo8obI7f4XYjhfZg61EC6a6JZCeK4kLPYi12cFijc3dQr7nYuye-ntOxPA4tllMCOUUyqGd2_4cI9PhDaL_-0Z8XV7hTaxJ678JtUC7ZTK1s9hRctPWK3Zi1THCGgy4UU0v8n_ZxSZOoWq2cSUvYPBY8RVQP3_4MBAfYRFcSmjqjb3idzxtAzerLR_UTWuovLsSkwbn30I6EY_JgY51eGH-5f9In-dFXjgOqLzcwf7knwOX3_B4I4J1pd8_Jmeqm_SOdJrhcg80OvSX7wytUxEcge_iFB-KiY_TJDVZzf06tgVpB0BnOw0gng2vkFPZ8z-07WCBQlJgzAiFA1w3SsNXN2fXBT0l8WSHcGWg6ptknbnZWvkGo5uWUz2blR9U4zwAhlr2Zg0v4aHM2fexkk119KqStmyiGXWE44Psmapn5Etky5BBYc_bsxRnf6i-_j2fNnrVuhiJZzThJv7V1JO0a4ruDp6AqWgY1K_lkpZM8HRiV8-ELxdPMOIVHgNSoidw4vZlVUAgVNy2vx14YHPHDUSQcmMyF43Y_WfZToDhnoyzWpjztame80Ymi6_3cFcmLKj8DYWC4LcxZqsfiZ9dtpSqyS4ebR3xqDCX5SPbAwx5_vOVckK3A=w1366-h616-no
The middle light is blinking and other 2 are solid. What is its major malfunction?
ahart
Indiana
You got a serial number for this machine? And are those the only 3 codes you’ve got?
ahart
Indiana
1235-9 : J1939 Network #3 : Abnormal Update Rate
The Pump and Electronics Unit (PEU), the ammonia sensor, the soot sensor, or a NOx sensor has incorrectly stopped or started transmitting a data request.
The ECM will log the diagnostic code.
5246-16: Aftertreatment SCR Operator Inducement Severity : High - moderate severity (2) **this code is a direct result of the above 1235-9 code.
190-15: Level 1 The engine has exceeded the value that is programmed into the Electronic Control Module (ECM) for 0.6 seconds.
There are no diagnostic trouble codes for the speed/timing sensors.
The engine has been running for at least 3 seconds.
I would say you are going to have to get CAT ET hooked to the machine to determine which sensor on the J1939 is causing the problem.
Ros$
SE Oklahoma
thanks ahart
this machine has been nothing but trouble. started it up this morning and i put all the coolant on the ground pretty quick. turns out the dang def heater valve (all plastic mind you) hangs almost below the bottom of the frame. guess i hit it on something the day before and when it tried to warm the tank up it opened the valve letting all the coolant out.
