Auwstin
hi my 753 bobcat is having an issue recently iv changed fuel filter air filter oil change and still having the issue where it will run for about as long as it would take to run the fuel thru the line (5 min) then die. I will have to go open the back door and reprime the ball and it will fire up just long enough to get in and move maybe 3 feet. with that being said let me say this my throttle will throttle up but as soon as u let off the throttle it will want to go back like the spring is holding good but it doesn't stay where u put it if that makes since please any help will do iv replaced the alternator and a few hydrolic lines and the arm within last 20 hrs since it's been ran. any advice will be much apreciated.
