Jasonbowling
I have a 2005 cat 277b skid steer. Had it about a month. While running it the seatbelt/lap bar light would come on. This would kick the parking brake on also. The parking brake light would be solid but the seatbelt woild flash. Once the flashing light went solid I could hit the parking brake switch and keep working. It was stating to happen more often, about once every 5 minutes. I also have an enclosed cab, so I dont want it to keep me from operating it while the arms are up. Dont want to have to do the rear window thing to get out!
So I tore it apart, when I pulled the ecm out.from under the floor. The plug, wires and ECM are dry. I unplugged the ecm connector and a yellowish fluid began filling the ecm area where the plug goes. The plug also had yellow fluid on it. Doesn't appear to be hydraulic fluid either. So did something let go inside the ecm???
