iowahill
- Joined
- Apr 18, 2015
- Messages
- 271
- Location
- Lincoln, CA
- Occupation
- Retired, owner of Thomas Fischer Company, consultant
To bring to a close of my education and resolution of the fuel problems with the Deere 820/2010 I found that deteriorated flexible fuel lines (2) and the surprising discovery that a formerly working fuel relief fitting off the injector pump was my final problem with shutdown. Removing it completely left me with a dangling fuel return line from the injectors that formerly connected to the barb connector on the relief fitting.
So rather than settling with the loose injector fuel return line I pulled the crimped wire restrictor out of the relief fitting, drilled the restrictor bore out with a 9/64" drill (purely arbitrary on my part as to size), and reassembled everything. It runs and starts perfectly now. The replacement cost for new flexible fuel lines was between $55 and $75 each, but I cut the crimp off the original fuel line fittings and used 5/16" o.d. plastic fuel line to slip snugly over the roaming stub. Perfect, and cheap!
Thanks again to all for the help and insight! -Tom
