roll it back to about 1600, TS? Even lower?
Enquiring 3406B operators want to know
This truck doesn't have a pyro or anything so I was just looking for clues. I only have a few grades I pull, none long enough to figure out The best practices.Drive it how ever you want to, I'm not repairing it or paying the bill.
Jack Crews said “Ain’t Nothing Like a Caterpillar Engine”. I believe him. View attachment 259926
You can check that pretty easy without swapping parts. Plumb a pressure gauge into the side of the block. Should run around 30 psi steady at speed. Best to be able to watch it while driving. Slipping on shaft can come and go with different temperatures.Hi after you have checked all of the above.check to see if the water pump impeller is not turning on the shaft.the impeller is a taper fit on the shaft and if not fitted correctly can come loose.
Also there were a batch of water pumps that had a plastic type impeller bonded to a steel hub, when hot the impeller would spin on the hub
Mark
Thanks, that is how I drive. if it won't accelerate then back out of that one and go a hole lower. This truck runs 175 and I might get to 190 on my little pulls. It has the air fan.Old rule of thumb, If your hard on the throttle to maintain speed on a grade or can't gain speed you need
to drop one gear. Should maintain speed easily at 65% throttle. If it's a 2100 rpm engine it should be pulling
easy at 1900 and running 195* to 200* with fan engaged.
