Columbo
This is a spin-off question from my thread on a Cat 311B excavator, S/N 8GR00401.
When I swing the machine it operates smoothly but at times I’ll move the lever to start swinging and nothing happens. If I wait 10-30 seconds it will swing like normal. I also noticed that some of the time when it was “stuck” I could move the lever the opposite direction and it would then swing normally in both directions. Curling the bucket also releases the brake and allows it to swing. Switching it in fine swing mode does not to fix this.
Since I had to repack the swing gear cavity I know that the outer swing gear is in good condition all around. Also, when doing that maintenance I swung the house in both directions numerous times without issue. To me, it feels like the swing brake isn’t disengaging. Also, on several occasions the swing brake would apply itself while I was working and actively swinging the machine which caused it to abruptly stop swinging.
It seems like an electric problem since it is intermittent. However, I also believe that the problem became worse as the hydraulic oil heated up? So I’m not sure where to go from here.
Suggestions on how to diagnose or repair this problem? I have a video of the problem but can’t seem to upload it to this site. Thanks in advance!
