Cummins has all but stopped support for the Small Cams, Big Cam I, II, III, Big Cam IV's and the 444.
Basically It's only N14's and up. N14 came out in 1992 so it's 30 years old. Problem is what you will
have is a warmed up 315 and probably not very impressed with it.
Most all parts will be aftermarket, and in most cases as good as Cummins. I have had good success with
Interstate McBee, Most of the gaskets will be PAI. Other small parts you will have to source on the web.
Just have the pump set up no more than 15% and AFC 10% over book. Biggest thing is condition of cylinder
block deck surface, that engine should be a NT88 block which will have lower press fit liners and counter
bores already cut for/and shims installed under liners. Blocks with LPF liners have way less counter bore
issues with leaking liners. A NT88 block also has a thicker deck area. But with all that said reality is
don't try to make more than 440 Hp. The HT 60 turbo from a N14 works well for more boost also.
Premco--in Texas is the place to send the pump and injectors-They can match flow injectors to precentage
of over fueling at the pump and account for more boost also.
Don't leave out getting 3 reman cylinder heads either. But one area that is always a concern on those old
855's is how many times has it been in-framed without changing the cam bearings/bushings. If it's idling
right now near 15 psi hot at 600 rpm, those cam bearings are the cause. Hot idle should see 19 to 21 psi.
Psi at 40 hot-if it's reading 35-cam bearings.
Pistons-use 4 ring double ni resist, doesn't really cost much more. The cam has to checked with a fine
tooth comb for any ware mainly on injector lobes. Cam followers need to be checked/each roller for
excessive up/down and side play-all rollers and roll pins can be had.
I think I have a PDF file for BC IV's I'll post it for you if I have it.
Some things to think about.
