old Italian construction site with old vehicles
trombeur
italia
do you like calabria? it's a beautiful land, too bad we have a bad mentality and we don't know how to value it. you can eat very well, the climate is warm and temperate. pity it's a poor land.
kgm__FYokt0JBSbfy80LIuWlYtF4q2Thorw0sXRhkmDT-bc3xOKDgfTaGCacrpENHlWXysw3gP0e6RroQclVqFaCYi1_vY8HIcBIbUjOlm4sjy77FAoPRBFwQEaeR4okiaCkTJl_B4WU1Hd6wVBHnFUonA
images
O2mTjhcKnESpFkctUI9w2qFCS1bs7f8dByP6VISaOER6SEFYaBLVa3XGWvgkG9-azzv2Pm6NVTnZfK9IWqiMoDrygfyzuDaHjNAn8KaRvhauwLM4ACTmxHUL0q5ou29jWLJn_xUBn6eKyUuiJ2CLb6M6btdD_g
pXfrQn5G_ih6CMagyjOR-kaOz7batPvE933sc8IoJF0jG8n3egYbMKZv6MuxkqVIBmfev1b8g9Yfmbudt0GjPEOyBslvfZKYWd_OU3TkX2oJmGGBaoK58nyfeyCkHJAkmUkiyoLaCjQO6OwGopBlpNqPdtBJ
trombeur
italia
bendini crane marina di gioiosa jonica
BENDINI 35 BETA ANNO 1990 GRU FUORISTRADA PORTATA 35 TONN
rough terrain crane)
4 wheel off-road crane with single track model Bendini 35 Beta (type 3 206 Beta) total mass 25200 kg
CAPACITY 35 TON, standard arm 3 pieces, telescopic, length from 8.8 m to 21 m
continuous rotation on 360 degrees, rope diameter 18 mm length 155 m
revolving cabin in soundproofed steel, tempered glass, adjustable seat.
levers with servo control, positioned on the armrests of the seat, hydraulic system with a double blade pump
and a gear pump, feed the 3 main circuits of the crane.
Blocking valves on the stabilizing cylinders, up and down stroke limiter, brake valve on rotation, maximum pressure valve
on each circuit.
Iveco Aifo engine type 8061 SI 6 linear cylinders water cooling
Clark 6-speed forward and 6-speed transmission, 16.00 R 25 ** tubelles off-road design tires
pneumo-hydraulic service and parking brakes acting on the transmission shaft with hand-operated pneumatic control
length with folded arm 11080, 3250 high, 2500 wide, width with open stabilizer feet 5800, wheelbase 3500 mm
4 steering or lockable wheels, max speed 36 km / h,
trombeur
italia
hanomag e dresser mf erano molto diffusi dalle mie parti, ci sono ancora alcuni macchinari nelle cave e negli impianti dalle mie parti,macchine veloci potenti agili e compatte,
hanomag and dresser mf were very popular in my area, there are still some machinery in the quarries and plants around me, fast, powerful, agile and compact machines,
trombeur
italia
trattore same
in the countryside I saw this old SAME tractor that has been transformed into a log loader, the owner bought an old telescopic crane arm from a scrap dealer, took it to a mechanic claw from logs to lift load move logs in the countryside and in the woods. what an ingenious man this peasant, peasant big-brain shoe up, what do you think?
trombeur
italia
