cuttin edge
Compression test? I guess the piston can crack in half on them. If you mess around with the glow plugs, be careful I guess they can give you quite a zap.
So any ideas how to ensure it's piston? It has blow by out the breather and exhaust. Assuming it is piston Im thinking to simply check temp of exhaust manifold to narrow it down to which side. Is it possible to get cylinder head off without removing cab? Looks like oil pan will come off. This way I can do this in frame. Then sell this truck!
I know this guy is a little controversial but I find him informative and agree mostly with his major points. I think he just gave up on 6.4s, they are becoming orphans.
I have a Ford 06 which I bought for wall work, as if I thought it was a great choice but... As it turned out that Ford made 6.0 and 6.4 not very good engines. Mine had cracked heads, although it worked perfectly, it surprised me when the problem became clear. And when I started to understand how much the repair will cost, I realized that for this money it would be possible to repair any other engine, and I just replaced the valves!
Although you may have a different situation, I advise you to check the compression in a service center, or if you have the opportunity to do it yourself.
You can't get the heads off with the cab on. Either cab off or engine out. Cab comes off in an hour and a half.
