JMR-TBAY
We always used the half circles like your first photo shows. The reason is that when the thumb is pulled back it slams into those stops and wear a matching groove in the linkages. I've seen plenty of machines with the single sitting in the center which hits the eye of the thumb cylinder rod and over time it makes a mess of the rod eye. The setup in your second photo looks good but uses a lot of steel and welding.
The semi circle rest would press against a beefy piece of linkage, not the cylinder end. It could be made out of 1/2” or 3/4” plate steel. Oh and for clarity, I’d fab 2 pieces, like the first photo.
Option A (wedge shaped stop) seems like it would be a little simpler to fab, and much beefier. Could use 1” steel to match what it would press against on the thumb. It would be about 1” tall on the short size and 2” tall on the long side and about 6” in length.
With either I’d try to attach some conveyer belt rubber as an added cushion.
My only concern with option A would be the cantilever effect it would have on the main pin. The lower the rest is to the fulcrum, the more force that will be cantilevered against the main pin when the thumb is stowed. Not sure if that’s a realistic concern or not.
