I am pretty good with stick building demolition. I want to give a quote for this block building with metal roof. I also need to break up and remove the slab it's on and the one beside it. Planning to rent a 6-9 ton excavator with a bucket, thumb and hammer. Size will depend on what's available.
Building dimensions are 10ft 9 inches tall, 13 ft 3" wide and 11ft 2" deep. The building slab appears to be 6" thick. The extension next to it needs to be removed and it's 11ft 2" by 4ft.
Machine is $800 per day or $1800 for a week. Hammer is $300 a day I forgot to ask the weekly rate on that.
The block walls I'm not too concerned about but I have no idea how long it will take the hammer to break the slab into loadable pieces?
I know I need to calculate the weight of building and slab to figure out how much container company will charge me in dump fee.
For those if you who do this type of demo often how long do you think it will take and what would you charge for the job?
Here are some pictures if the building. Thanks for the help.
