Sailorman
I've got tracks pads back on, changed trans and engine oil and filters and seems to be working fine on my new to me 1965 Case - unknown # of hours.
And I have solved the areas mosquito problem with the 2 qt/ hour oil consumption. There is little blow-by coming from the crankcase ventilation hose. There is actual oil coming out the joint between the manifold and exhaust pipe. I first thought the valve guide seals were back. And now a line of oil only on the exhaust side where the head joins the block. Intake side is clean. Friend suggested the head gasket is bad allowing the intake stroke to pull oil past the gasket and into the cylinder. Engine starts wo much effort, seems to run well with maybe a slight knock. Oil pressure starts at 70 and drops to almost 0 when hot at idle. Suggested diagnosis for the oil consumption?
