Bobcat T770 problems
Shimmy1
North Dakota
Serial AT6315542
Need seal kit for drive motor. Apparently none available in the country. Have contacted Bobcat directly with no luck. They are claiming 30 weeks.
AzIron
Az
Motion industry's
Possibly sun source would be worth checking
Chances are that rexroth is using those drive motors in other applications
Shimmy1
North Dakota
Anyone else have any ideas?
Drive motor 7440632
Seal kit 7324103
All I really need is this seal 7324104
DB2
Winnipeg MB Canada
No decent hydraulic shops nearby? Try Kepco in Winnipeg. Probably need dimensions. They sell seals not motors.
Bloody Knuckles
Blair Ne
DXP in Sioux Falls might be able to help with just the seal but DB2 is right they will need dimensions. OD of the shaft, ID of what it's being pressed into and if it's a double lip seal
  • Like
Reactions: DB2
farmerlund
North Dakota
Farmer/ excavator
My brother is at the factory in Gwinner. I sent him the information. Will see if he finds anygthing
Shimmy1
North Dakota
Thanks. I have a close friend also whose brother is a high-brow engineer there.
This is asinine. The problem is this motor is proprietary to Bobcat. Rexroth produces it, but will not sell parts for it. Had a guy today that has tried before, but has only been able to get the seal from Bobcat. Also, to complicate matters, this seal isn't some ordinary lip seal, so it can't be outsourced.
Thanks everyone who has tried to help, but this is going to fall directly on Bobcat's head. We have filed a complaint with the corporate office, hoping they will pull a motor off the assembly line, but havent heard back yet
Shimmy1
North Dakota
This isn't going to be an option from what I'm being told. This seal is some proprietary design only produced for Bobcat.
Bloody Knuckles
Blair Ne
I was thinking about this today and was wondering if Bobcat had a Proprietary Purchase Agreement with Rexroth.... We use to run into that every once in a while on large equipment bearings and electronic equipment where the component manufacture had it but you could only get it from the machine assembler.
farmerlund
North Dakota
Farmer/ excavator
Not looking good Shimmy. They can't even get enough drive motors to build new machines. He is still looking but not having any luck.
