LOFAYTX
Guys I have been thinking about this for years.
Will it work Convert Komatsu D65E with PS transmission and torque convertor to D60 Manual Clutch keep PS transmission?
Use the clutch to stop and start the tractor but be able to shift up or down a gear in forward while plowing. It would cut out
all the heat buildup from the torque convertor.
I have a D65E with bad Cummins engine with the old external fuel lines. I want to power it with a little newer Cummins engine that has internal fuel passage and a turbo. I will set it up with not too much more HP than it had. I want to build it as a plow tractor. I know its a lot of work but I love a challenge!
