dieseldog5.9
Spokes are in good shape, open rims are cheep, you may be able to buy a radial rim and an 11r22.5 tire
Gun them but know your gun.
Considering my truck has budds I watch tire guys very closely, one did not appreciate what I said would be a good alternative use of a torque wrench since they didn't want to use it for it's intended purpose. Neither guy could understand why it was wrong when every lug the wrench clicked immediately, no movement, and even after I told them it means they are over torqued they couldn't careless. It's scary how many tires they are responsible for putting on, that could potential kill people if they come off.
3 ugga ugga dugga's and I'm there!
Nothing special about budds, except theres twice as many nuts to take off.
If you want your tires done a certain way, change them yourself. If you're not competent to do it yourself, don't take it to someone else and then complain how they are doing it. If you have time to watch, you've got time to help, if not- go drink coffee somewhere else.
And how do you know your air wrench?
You are not alone. Do you put anything on them putting them back?Many years using one. I've never lost wheels, but one item I do that I see no one else doing, I spray the studs
down with penetrating fluid first to remove dirt-saves the threads taking them off.
A whole front axle from rydemore is cheaper than buying all the parts.
What do you do with a fuel tanker like that and this will not get the job done?
I've got one old crane that if I keep it- I think I can cheaper find a full tandem cut off with a 5 something gear ratio, and just swap the whole thing in one shot. Get rid of my 20" rubber, wedge brakes, and the ancient rockwells that are under it.
Its twin steer up front, I might have to get creative switching them.
I hopped my lowboy all over my yard trying to get the wheel studs off it. Air gun wouldn't touch them, and then I was right after them like you with a 12' cheater. I first spun the wheels (empty tri axle trailer doesn't have much grab), then I chained the wheels up and was bouncing the trailer around the yard. I finally got one of these:
They look like a bunch of chinese junk, but the stupid thing works. Its a lifesaver on the side of the road with no air.
https://www.amazon.com/XtremepowerUS-Torque-Multiplier-Saving-Wrench/dp/B00MI0DOW6
Yes they do.I've got one old crane that if I keep it- I think I can cheaper find a full tandem cut off with a 5 something gear ratio, and just swap the whole thing in one shot. Get rid of my 20" rubber, wedge brakes, and the ancient rockwells that are under it.
I have roughly 1,200 wheel ends to deal with, that's 12,000 studs and 12,000 nuts.
Just WD40 or so on studs.
First job of the day yesterday-replace four air disc rotors and brake pads all inboard, 1 1/2 hrs per corner.
It's constant brake work and tire work. 60% plus of my work is dealing with wheel ends.
Wait till one of you have a hub pilot aluminum wheel fused to hub. 90% of the time you can go through
wheel holes and bar off of drum or rotor to break loose soaked in penetrating fluid, then there's the
10% that you install four nuts loose and drive around doing figure 8's to break them loose. Salt and
de-icing fluid will corrode them in place in one year. I've had wheels that took 1 hr to remove.
When dealing with this many wheel ends-a constant every day exercise you get to know what your doing,
I don't have time to by the book every lug nut, that's fantasy. And again I've never lost any wheels or
wheel ends.
