Yes, Happy New Year ! Looking forward to seeing pictures of someone else’s 977 adventureYou’re way ahead of me. I did 3 months work on my house. Dry rot all ripped out and replaced and entire 3,500 two story fully primed and painted. I hope to get the 977k in good condition by Spring. Speaking of spring I’ve gotta tackle that beast.
Happy New Year!
Chris, is there any way you can jiggle brackets, fasteners, etc, around to get the hydraulic hoses on the LH side of the machine away from the lift arms like the ones on the RH side.? I'm wondering if at least some of the damage you showed on your photos was caused by hoses rubbing on steel.
Thanks, yes have managed to move them a touch so they all clear the loader arms and the bonnet, took a few attempts to get them where they needed to be as there’s not much room to spare between the loader arms, hoses and bonnet.^+1
you ought to be able to just loosen the top or bottom clamp a bit, and rotate one end and it will dial the hose away from the lift arm. Nice catch, @Nige
Thanks Sam, any advice would be welcomeChris, I have enjoyed reading you thread along with several others on rebuilds . I reworked a 955H almost 30 yrs ago it took me 2yrs working every spare minute I had.The first time I filled it with fuel it was .68 a gallon. I have ran it thousands of hours since then and it’s on a job now.Doing things right to start with pays off. If you have trouble getting someone to bend spring guards I think I can show you a simple way that works. I made some for mine that work fine. I just reworked View attachment 251304 a 4&1 bucket for it.Will try to View attachment 251303 post some pictures. Sam
Yes, I have been thinking of this tooWhat about wrapping the hoses for additional protection? My 955 are wrapped
Thanks Sam, that’s great, I’ll get some plate sorted.Hey Chris, hope this is something you can use. I used 11 gauge 1/8”material,8”H beam and 6 1/2” heavy wall pipe. I think your roller frame is wider so you will need to adjust beam and pipe size to fit your needs. I bent mine in a press took less than 20 ton, I think you could use a large trackhoe or other machine if needed.All pieces can be bent the same and then the ones in front that go to front idlers can be spread to fit on top so they can slide.Drill holes in flat bar and bolt up then put guards over springs and weld to flat bar.Make pattern to cut shape and drill to fit idler yoke, cut window for grease fitting.Might want to bend a test piece. Let me know if I need to clarify. Sam
Those are some good looking gaurds,I would love to see how you made them.Chris, I have enjoyed reading you thread along with several others on rebuilds . I reworked a 955H almost 30 yrs ago it took me 2yrs working every spare minute I had.The first time I filled it with fuel it was .68 a gallon. I have ran it thousands of hours since then and it’s on a job now.Doing things right to start with pays off. If you have trouble getting someone to bend spring guards I think I can show you a simple way that works. I made some for mine that work fine. I just reworked View attachment 251304 a 4&1 bucket for it.Will try to View attachment 251303 post some pictures. Sam
