PeterG
I bought another trailer, and would like to weld on D-Rings every two feet or so along the sides. The normal place is on the sides. What I don't like about this is it makes the trailer wider with chains and binders etc, plus with the D-rings jammed along the sides you loose some D-ring space and they pull at weird angles. I prefer to just weld them on top of the sides.
I likely will never have anything that wide that they would be in the way, and I also don't think walking around the equipment when standing on the trailer would they be much in the way. Why don't the manufactures well them on top? On this Trailmax it has chain loop holes on the top, so they understand the angles of straps and chains. Opinions?
