Clawed Backster
So, I've got an old 555 that starts instantly, runs great, and all of the mechanical features work as they should.
However, the entire electrical system was abandoned many years ago by a previous owner. The only electrical thing that functions is the starter. I just keep the battery topped off with a maintainer when the machine is parked. Now I could spend countless dollars and countless hours repairing or replacing the wiring loom, or I could do a little hillbilly engineering.
My solution? A $180 generator from Tractor Supply, and a couple of work lights that I already had. I just needed to mount the lights, and strap the generator to the fender.
Works great, but I can't run both lights at the same time as the generator is only rated for 800 watts continuous.
