Update: I connected the shut off solenoid directly to the battery (positive and negative) and same issue after initial start up. I cleaned the relay connections and swapped them around, as they are the same, and still no start ( which was no surprise) . It would sometimes start back up 2 or 3 times, but there was not anything I could say was consistent with why it would start. Today, just to eliminate everything I can think of, I took the return line (very small metal line on top of injector pump) loose and where it transitions to rubber and blew it out. Fuel immediately came out of the rubber hose that goes back to the tank before I clamped it off, so no restriction there. Didn’t make any difference. The day I went and looked at this machine, we started and stopped it several times. Same thing the day I had it picked up and when I got it unloaded and parked, went to start it back up and that’s when this all started.
