bsamot69
Yes. Another piece of equipment...Peterbilt dump truck, believe it is 379. I got a message it is not cranking. At truck, I check batteries, 2 in this unit, both have good voltage, 12.8 and load test good. It would click when dash button pushed. I went to starter and tried jumping the s terminal and battery connection on the solenoid looking thing mounted to starter. It just clicked. I noticed a solenoid on fender well but wasn't sure it's function. I have since read it sends voltage to the starter. I then connected battery positive jump cable to starter motor lug and ground cable to negative lug then touched negative cable to battery negative expecting the motor to run. Nothing. I pulled the starter and cleaned up the terminals and connected battery to starter and remote switch to s terminal and push button. The solenoid clicked a couple of times, the gear didn't move nor motor run. Connected direct to starter motor and touch negative to negative lug on starter. Get a spark but no motor run. I'm using a new battery for these tests am I missing something here? Is this a bad starter? Am I connecting.my cables properly? This huge piece of metal, heavy and cumbersome has me second guessing myself. I checked the resistance between the starter motor positive lug and the ground lug on front of motor. The resistance is 0 ohms . I expected a much higher value. Any suggestions are greatly appreciated.
