I've got a 955k that I got stuck in a hole and the right track came loose when I finally got out. I've put about 6 tubes of grease in it and I can't get it tight. I'm guessing that I pushed out a seal on the adjustment. I can't find where it's coming out of. I'm guessing that I have to break the track and remove the tightner and spring assembly and take to cat to have rebuilt. I don't have a press big enough to remove the spring and have heard stories about spring releases. Am I going down the right track?
