Received an email in the overnight hours and it appears this machine is local to me it's entire life. No real history other than it was the only one of it's type in the area. New in 1972 and rotated through in 1978.
The next 20 years are probably lost to history as the guy I basically got it from purchased it in 1998 from a long defunct machinery dealer in the area.
One of the hoses is emblazoned "Caterpillar" so either the local Cat dealer has worked on it, or somebody brought hydraulic parts home from work with them. This area has many Caterpillar facilities so anything is possible.
Yesterday I did discover the hoses when disconnected from their attachment points are quite long and curled, or rolled up a bit behind the backhoe valve body. It appears with the hydraulics connected, one would run the boom and bucket down touching the ground, remove the upper pins retaining the backhoe assembly, deploy the outriggers slightly lifting the backhoe assembly from the "sockets" the lower pins set into, drive forward a few inches, and then disconnect the hoses. The backhoe forms it's own stand this way. With new and flexible hose this wouldn't be too difficult but given these are very stiff, it's not that easy. It also appears as the tractor is moved forward of the backhoe attachment, the rear is open meaning access to the quick disconnects is quite easy. I don't know why the supply line fitting has had the plumbing fittings installed angling the fitting, but I surmise the original orientation was rearward facing as the return connection is? More on this as I figure it out along the way. Surely wish I had some type of manual, or experience with such things but it is what it is I suppose.....
Got to pick up a small dealer transfer farm tractor down south of St. Louis this morning so will continue the updates later when they happen.
Thanks,
