To help start a fire and keep it burning, tires are illegal, but in my state its legal to burn waste oil or any type of fuel in order to get the material to burn, its not allowed to basically use the material as a reason to burn the fuel.
We've used about everything there is to get fires going, most of what we've used was given to me, as in vandalized vehicles and equipment fuel that was contaminated with something and nobody would take it, at one time we had a couple thousand gallons of waste junk to burn up and get rid of, most of the diesel was contaminated with acid and the gasoline with water or some chemicals, the waste oil, I really have no idea what was in it but the thing I've learned is this, if its free, you really don't want it. We've only used a 20lb lp tank and weed burner for decades now, one 20 lb tank will enough to burn 20 acres of green live timber, maybe even more if the weather cooperates.
I usually tell people we're going to burn, if there is something you'd like to get rid of and doesn't contain steel or nails, bring it out and toss it on, after all its your fire use it to get rid of the stuff you don't want laying around, beyond that it really doesn't take much to get and keep a fire going.
Dry dead material any idiot can burn, live green or water logged material needs to be handled, prepped and burned in a far different method than dry, different species of tree's need a different approach in order to get to burn, green willows four feet in diameter takes a far different approach than a foot diameter green oak tree or cedar, same goes for brush or anything else, humidity, wind speed, temps all play a huge role as well, along with the time of year, in the dead of winter when the tree's are drier, is much easier than the spring time when the sap is heading up into the tree and literally making the tree's wetter.
Blowers and things might be needed in some areas and under some conditions to get stuff to burn, in my area I've never used or needed them, I personally think they are a waste of time and money, other areas and different conditions if I lived there, I might feel differently and use them. I know people around me use blowers, have for years and still get marginal results in burning green material. I've burned green stuff every day while it was raining if the mud wasn't too bad to deal with and no issues whatever getting all the stuff burned up.
It gets down to experience, what your dealing with and the conditions your doing it in and how much is wanting to be spent to get the job done and the equipment you have to do it with. Every job is different, each takes a different approach to get the wanted end result, there is no such thing as a one size fits all, never has been never will be and 20 different people will do the exact same job 20 different ways to get it done, doesn't make one right and the other 19 wrong, as they say to each his own and if the job gets done to the person doing the hiring satisfaction, then it was done correctly.
