Your dozer photos
Claus
Hebron In
Would like especially to see crawlers with 3pt hitches, winches, root rakes and rippers!
DPete
Central Ca.
Little 6R pulls it weight around the job, had 2 D8K's prior and am impressed with what the 6 will do for its size
A couple of my D5G
tuney443
Dutchess County,NY
excavating contractor
If somebody here that knows how to post pics can run me through the how-to,I have the neatest pic of my little JD 450D pushing around a JD762 self loading scraper for a week at an IBM complex 28 years ago.
DPete
Central Ca.
Click ( Go Advanced) on the reply page at the bottom of that screen is a (manage attachment) button click and follow instructions click ( add files) upper right. I always resize mine to 640 pixels first
mitch504
Andrews SC
Don't even have to go advanced, the next to the last button at the top of quick reply is the insert image button.
DPete
Central Ca.
OK here's my other dozer, 1961 D4 , needed to try Mitch504 button been doing it the hard way LOLD4 BeGe 004.JPG Hey Mitch, much easier
mitch504
Andrews SC
Hey man, that's how I handle websites and equipment, I just push random buttons and pull levers and see what happens.
Scrub Puller
Yair . . . This is a great thread!
Dpete. What a nice looking little D4. I am bemused by the simple geometry on those blade lift cylinders but obviously they work okay.
Question about rippers. There is a thread on here about tine angle when using a four barrel. I mentioned that with the single tine Kellys they always reckoned the optimum angle in most material was with the tine vertical when at working depth . . . apparently the theoretical best penetration and bust-up rake was built into the tine profile.
It was mentioned that these days the tines should be curled under. Would that apply to such tines as are fitted to the tractor in the second picture on Saddleup's #14 post . . . not sure what it is, an eight something I think.
Cheers.
OCR
Montana
Rancher/Farmer, Wildland Fire Fighter, State snowp
That was odd, just push buttons, huh?... thanks Mitch. lol
OCR
JBGASH
Missouri
Plumbing & Excavation Contractor / farmer
My "dozer"
Here is my "dozer" and it works quite well and will do other functions, load trucks, haul pipe with forks and is only 1- machine to keep up
DPete
Central Ca.
Cheers.
Thanks, it's pretty much a cherry for a 61' No sturdy main frame back then so they used the swing frame brackets to hoist the dozer
This is not my D5G but one I was running in Costa Rica and came across this croc in the grass I wash pushing -
Sort of a dozer pic.:D
